- Mon Aug 10, 2009 9:09 pm
#78613
My parents mentioned that they would like something like this, so I figured while Ive still got the chance to use my schools lab before exams are done (and we go on a 1.5 month break) I would get it built.
Basically, the volume difference between commercials and tv programming is very large, enough that they have to turn the volume down during commercials and back up during regular programming.
I did some googling and found this site:
http://www.redcircuits.com/Page67.htm
I modified it a bit to remove the "control-flat" switch, as I want it to always be in auto-volume-control mode. Other than that, Ive kept the circuit the same. I plan on hooking it up inside the TV, splicing into the wires going to the speakers. The only other change I made to the circuit was putting a connector footprint in place of the gain pots, so I could re-locate the pots (hence the pots missing on the schematic).
Attached is the schematic (WIP - Power supply section is being worked on right now); once the schematic is good I will create the PCB layout and update this post.
I had one question about the project, though - do I NEED to use polyester caps? Remember this is going to be in a 6+ year old TV, and used for antenna broadcasts. Im sure they will be able to live with less-than-perfect sound quality.
Please look over the schematic (click for a bigger version) and tell me if I need to make any changes (or if Ive broken any basic schematic-drawing rules). My last day at school is Thursday, so I must have this done by then. Thanks!
EDIT PSU section added. JP5 goes to a 15-0-15 transformer
