wjb21 wrote:Is the RF-MiRF module FCC approved? My understanding is that even if the device is low power and in an unlicensed band it still needs to go through part 15 and 17 FCC approval. I would love to be corrected...
Regards,
Will
Take a look at this document:
http://focus.ti.com/lit/an/swra048/swra048.pdf
At 1 milliwatt, there is no way (other than perhaps with a very high gain
directional antenna) to exceed the field strength levels that would
cause a problem getting certified without frequency hopping (with frequency hopping much stronger signals are allowed). So, if
you went to an FCC-approved lab to have it certified it would be certain
to pass. It is my understanding of the law (and I could be wrong - I'm no
lawyer) that if you are selling commercial products then you need to
do the certification (which is a several thousand dollar expense). It
seems to me that should not be necessary if, from fundamental calculations, you can show that the signal levels are going to be
acceptable. But, the world is rarely the way I think it should be.
