By amabitxs
#200033
I made a cat feeder. The old one started running constantly so I replaced the main board with an Arduino Duemilanove. Any feedback would be appreciated. I'll add another picture once I get it all put back together.
//#define DEBUG_ON_SERIAL
//#define FEED_NOW
#include <Wire.h>
#include <SparkFunDS1307RTC.h>
#include "Arduino.h"
Pin out: Duemilanove
A4 - SDA
A5 - SCL
2 - Rd Feed Sensor
3 - Wr Motor Run Switch
4 - Rd Button for extra/immediate food
// Const's
const int SENSOR_PIN = 2; // feed sensor
const int BUTTON_PIN = 3; // button to manual feed
const int MOTOR_PIN = 4; // NPN transistor to run feeder motor
const int LED_PIN = 13; // Onboard LED
// Variables
int timeTillNextFeeding = 719; // old diff
int timeFromLastFeeding = 50;
int motorRunning = 0;
int feedAmount = 6;
class myTime
  To easily compare two times
  public:
    myTime();
    myTime(int, int, int);
    myTime(uint8_t, uint8_t, uint8_t);
    bool operator<(const myTime &rhs) const
      if (this->getH() < rhs.getH())
        return true;
      else if (this->getH() == rhs.getH() && this->getM() < rhs.getM())
        return true;
      else if (this->getH() == rhs.getH() && this->getM() == rhs.getM() && this->getS() < rhs.getS())
        return true;
      return false;
    bool operator==(const myTime &rhs) const
      if (this->getH() == rhs.getH() && this->getM() == rhs.getM() && this->getS() == rhs.getS())
        return true;
      return false;
/*    bool operator>(const myTime &rhs) const
      if (this < rhs || this == rhs)
        return false;
      return true;
/*    void printVars2(myTime &rhs)
      Serial.print("-->");
      Serial.print(String(this->getH()) + ":");
      if (this->getM() < 10)
        Serial.print('0'); // Print leading '0' for minute
      Serial.print(String(this->getM())); // Print minute
      Serial.print(" | ");
      Serial.print(String(rhs.getH()) + ":");
      if (rhs.getM() < 10)
      Serial.println(String(rhs.getM())); // Print minute
    int timeDiffT(myTime &rhs)
    // returns the minutes diff between this time and passed time
      int first, secnd;
      first = (this->getH() * 60) + this->getM();
      secnd = (rhs.getH() * 60) + rhs.getM();
      timeTillNextFeeding = secnd - first;
      if (timeTillNextFeeding > 720)
        first = first + 1440;
      if (timeTillNextFeeding < -720)
        secnd = secnd + 1440;
      timeTillNextFeeding = first - secnd;
      delay(500);
      return timeTillNextFeeding;
    void setH(int h) { H = h; };
    void setM(int m) { M = m; };
    void setS(int s) { S = s; };
    void setMyTime(uint8_t h, uint8_t m, uint8_t s) { setMyTime(int(h), int(m), int(s)); };
    void setMyTime(int h, int m, int s)
      setH(h);
      setM(m);
      setS(s);
    int getH() { return H;};
    int getM() { return M;};
    int getS() { return S;};
  private:
    int H;
    int M;
    int S;
void pulseLED();
myTime::myTime() { setMyTime(0, 0, 0); }
myTime::myTime(int h, int m, int s) { setMyTime(h, m, s); }
myTime::myTime(uint8_t h, uint8_t m, uint8_t s) { setMyTime(h, m, s); }
myTime feedTime;
myTime currTime;
myTime lastFeedTime;
int timeDiff(myTime &lhs, myTime &rhs)
  // returns the minutes diff between two passed times
  int first, secnd, diff;
  first = (lhs.getH() * 60) + lhs.getM();
  diff = secnd - first;
  if (diff > 720)
  if (diff < -720)
  diff = first - secnd;
  //delay(500);
  return diff;
bool timeToFeed()
  timeFromLastFeeding = timeDiff(lastFeedTime, currTime);
  timeTillNextFeeding = timeDiff(feedTime, currTime);
#ifdef DEBUG_ON_SERIAL
  Serial.print("timeToFeed --> L: - ");
  Serial.print(timeFromLastFeeding);
  Serial.print(" -> N: - ");
  Serial.println(timeTillNextFeeding);
#endif
  if (timeFromLastFeeding < 5)
    return false;
  if (timeTillNextFeeding < 5 && timeTillNextFeeding > -5)
    return true;
  return false;
void feedTheCat()
  Serial.print("feedTheCat --> ");
  Serial.println(motorRunning);
#endif
  if (timeToFeed())
    motorRunning = feedAmount;
    digitalWrite(MOTOR_PIN, HIGH);
  while (motorRunning > 0)
    delay(2000);
    //--motorRunning; // backup in case the interupt isn't working
  digitalWrite(MOTOR_PIN, LOW);
void setup()
  Serial.begin(9600);
  while (!Serial) { ; } // wait for serial port to connect. Needed for native USB port only
#endif
  // initialize input / output pins:
  pinMode(LED_PIN, INPUT);
  digitalWrite(LED_PIN,HIGH);
  pinMode(MOTOR_PIN, OUTPUT);
  //digitalWrite(SENSOR_PIN,HIGH);
  pinMode(SENSOR_PIN, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(SENSOR_PIN), increment, FALLING);
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(BUTTON_PIN), interuptFeedNow, FALLING);
  rtc.begin(); // starts clock
  //rtc.autoTime(); // should never need to be run again
  //rtc.setTime(s, m, h, day, date, month, year)
  //rtc.setTime(0, 11, 23, 7, 11, 8, 18);
  feedTime.setMyTime(7,30,0); // hrs, min, sec
void loop()
  int i = 0;
  rtc.update(); // Update RTC data
  currTime.setMyTime(rtc.hour(), rtc.minute(), rtc.second());
#ifdef FEED_NOW
  feedTime = currTime;
#endif
#endif
  if (timeToFeed())
    Serial.println("**** FEEDING ****");
    delay(1000);
#endif
    feedTheCat();
  printTime();
  printVars();
#endif
  //    pulseLED();
  if (timeTillNextFeeding < 0 && timeFromLastFeeding > 0)
    //sleep for 60
    Serial.println("**** SLEEPING for 60 mins ****");
    delay(2000);
#else
  // what do do in real time
#endif
  else if (timeTillNextFeeding > 30)
    //sleep for 30
    Serial.println("**** SLEEPING for 30 mins ****");
    delay(2000);
#else
#endif
  else if (timeTillNextFeeding <= 30 && timeTillNextFeeding > 5)
    //sleep for 3
    Serial.println("**** SLEEPING for 3 mins ****");
    delay(2000);
#else
#endif
  else if (timeTillNextFeeding <= 5)
    //sleep for 3
    Serial.println("**** SLEEPING for 15 s ****");
    delay(1000);
#else
#endif
void increment()  // Really a decrement... shuts down the motor when the counter gets to less than zero
  Serial.print("**** Interupt 1 **** Cups left to feed: ");
#endif
  delay(50);
  --motorRunning;
  if (motorRunning < 0)
#endif
void interuptFeedNow()  // Really a decrement... shuts down the motor when the counter gets to less than zero
  Serial.print("**** Interupt 2 ****");
#endif
  delay(50);
  increment();
  Serial.println();
#endif
void printTime()
  Serial.print(String(rtc.hour()) + ":"); // Print hour
  if (rtc.minute() < 10)
  Serial.print(String(rtc.minute()) + ":"); // Print minute
  if (rtc.second() < 10)
    Serial.print('0'); // Print leading '0' for second
  Serial.print(String(rtc.second())); // Print second
  if (rtc.is12Hour()) // If we're in 12-hour mode
    // Use rtc.pm() to read the AM/PM state of the hour
    if (rtc.pm()) Serial.print(" PM"); // Returns true if PM
    else Serial.print(" AM");
  // Few options for printing the day, pick one:
  Serial.print(rtc.dayStr()); // Print day string
  //Serial.print(rtc.dayC()); // Print day character
  //Serial.print(rtc.day()); // Print day integer (1-7, Sun-Sat)
  Serial.print(" - ");
  Serial.print(String(rtc.month()) + "/" +   // Print month
  String(rtc.date()) + "/");  // Print date
  Serial.print(String(rtc.year()));        // Print year
  Serial.print(" .. ");
  Serial.print(timeTillNextFeeding);
  Serial.println();
void printVars()
  Serial.print("-> ");
  Serial.print(String(feedTime.getH()) + ":");
  if (feedTime.getM() < 10)
  Serial.print(String(feedTime.getM())); // Print minute
  Serial.print(String(currTime.getH()) + ":");
  if (currTime.getM() < 10)
  Serial.println(String(currTime.getM())); // Print minute
#endif
By Valen
#200372
1: You lack a diode across the motor terminals. Once the transistor shuts off the energized coil causes a voltage spike that could damage the transistor. Connect the diode such that the cathode is on the positive motor terminal. When the transistor turns off the current can flow back to the positive motor terminal and disipate the magnetic field. The led won't solve this as it is the other way around.
2: Fritzing diagrams do not show the proper pin orientation. It doesn't show emitter, base and collector orientation for transistors. Same goes for the switches. How could we tell the conductive path between the 4 terminals. A normal electrical symbol schematic would (if done properly) So for all we know your circuit could fail to work because of wrong transistor and/or switch orientation.
Codewise: It could use some clean up jobs! Seems like there are a bunch of code-leftovers. Which doesn't entice me to look too deep into it. Too confusing
Comparing time in that myTime class. (specifically the operator definition) Isn't it easier to just multiply hours by 60 and add minutes to get the minute-of-the-day (ignoring seconds for simplicity but adding that level of precision isn't that hard) and compare those? Your solution seems rather convoluted with if-statements.
You do seem to do that already in the function timeDiffT. Hmm, above it you define the < and = operator for the class but comment out the > operator. Strange business.
In setup LED_PIN is configured set as input and subsequently written high! Doesn't hurt, but strange also.
You introduce several delay statements (multiple seconds) in code parts that are only compiled in when a compiler directive is set "DEBUG_ON_SERIAL". Doesn't that cause irregular timing behavior? Why wait at all?
Probably more could be said about it but this is where I leave it.
