Can be used with normal serial, I2C, SPI, and any other digital signal.???
fll-freak wrote:You do not. I2C is bydirectional. The Sparkfun level converter is mono directional. You will need a different approach.Incorrect. The Sparkfun LLC is unidirectional on the RX lines. The TX lines work in both directions just fine. The typical approach is to connect SCL to pin 1, and SDA to pin 6 on the breakout board.
