- Wed Feb 09, 2011 1:40 pm
#119779
I recently purchased the power driver shield: http://www.sparkfun.com/products/10305 and love it!
However, I've already outgrown it. I'm trying to make several wirelessly-controlled stations that run LED strings (Christmas lights), but the strings are designed to run off-the-shelf at 120v. The Mosfets on the board are limited to 60v, so I was wondering if it would be as simple as just inserting a higher voltage logic-level Mosfet, like the STP80NF12 http://parts.digikey.com/1/parts/102562 ... 0nf12.html and then running it off of 120v?
I suppose I'd have to remove/modify the 12v LED indicator (or else I'd burn it up), but as far as using the new Mosfet for PWM control of my LED light strings at 120v, what do you think?
Also, there is a rectifier in the light string already, but would I need to rectify the A/C before it gets to the Board/Mosfets, either for the sake of the Mosfet, or to eliminate zero-crossing? I know Triacs are usually used with A/C, but this seems like an easier way to do what I want (I'm still playing with a Triac circuit, but zero-crossing is kicking my butt, and I'm having a hard time finding clear information on how to dim my LEDs with a Triac through an Arduino, and not a potentiometer).
Thanks for your thoughts/advice!
-Jason
-Jason
