- Mon Jul 05, 2010 12:23 pm
#104558
But technically, you must follow the regulations. The most important things are low power and use only frequencies set aside for public/unlicensed use. Don't interfere with an important radio service, and don't jam out your neighbors' garage door openers or wireless thermometers!
MitchV wrote:Hi Steve - I'm sure you're right (you sound like you know a LOT more than I do on the subject!). What I and others really want to know is exactly what is or isn't legal to do with these things. While I realize there aren't exactly FCC police that will come get you if you build something that uses these, I'd like to stay within whatever regulations apply.If this is for hobby/experimental purposes, not commercial, then perhaps you should follow the spirit and intent of the regulations for unlicensed spectrum. It's all about sharing, not hogging. If you transmit very frequently, as does 802.11 and some uses of 802.15.4, then use CSMA/CA (listen before transmitting). In the 450MHz and lower bands, cheap hardware, transmit-only hardware, cannot do CSMA, therefore the regulations and courtesy says don't transmit often. It's all common sense.
I know it's complicated and the regulations have everything to do with power, antenna, etc, but is it safe(ish) to say that as long as you keep power low (and I realize that's subjective), we're OK?
